Chris Kouba
I am in the process of assembling my fuel system and think I have come up with a plan but would like to run it past the collective braintrust on this site.
I have an RCR with bladder tanks, SBF crate motor and Edelbrock EFI. The bladders have a send and return on their aft ends and a large dia filler neck and small dia vent tube fitting on their fwd ends. Just aft of the filler neck is the level sender mount.
For the purposes of this discussion, I will separate the high pressure system from the low pressure bladders to swirl tank.
At the aft end of the left sponson is a tank in the chassis which I intend to use for a swirl tank. I will draw from this tank, through a filter, through the HP pump, through another filter, to the fuel rail and then plumb a separate return from the rail to the swirl tank.
In THEORY, that should take care of the HP side, right?
The LP side is what is giving me questions.
It seems like it'd be pretty straightforward to plumb a pair of lines from each bladder to the swirl tank, one via a filter and a LP pump and the other just a straight return line.
The single vent line at the fwd end should likely be connected with the filler tube (somewhere near the external gas cap, right?) and a rollover vent, correct? Any recommendations for a vent?
I am tempted to run without a selector valve- seems like it's not completely necessary and it'd be an additional opportunity for something to fail. With the unrestricted return lines, cross-filling would be controlled by individually powering the LP pumps. If one is turned off, the return feed will continue to fill the tank based on the volume being pumped from the opposite tank to the swirl tank.
Conversely, feel free to tell me I'm way off course here as well.
One of the major questions I have is will that rollover valve at each side prevent the build up of high or low pressure in the bladders as the gas expands on a hot day or is consumed while being driven.
What other concerns should I have/am I overlooking? What would you do if you were doing it?
Pics can be posted later if you would like them for clarity.
Thanks in advance,
Thanks in advance,
