This past weekend was a blast sorting out my GT-40. After a number of drives I ran into an overheating issue that appeared as follows:
1. The raidiator was cool - but the temp gauge was reading hot.
2. Would get boil over at the cap.
First thought - bad thermostate. Replaced that - with the help of Eric and Ralph (thank you guys made it much more fun). Seemed good. Went for another drive - everything seemed fine. Eric was following - when i got on the throttle he indicated that it seemed like mist was coming out of the exhaust. The car continued to run fine - then about 10 minutes later started heating up again - i pulled over - had overflow at the header cap - and again a cool radiator.
At this point i was worried about a blown head gasket - but the engine was running great.
After it cooled, refilled the head tank and started up again it warmed up fine - radiator was hot, and the temp was stable.
I had the engine cover up, and hit the throttle a few times - then i noticed steam from the engine compartment - seemed that everytime i hit the throttle - water would overflow at the radiator cap. So, first thought - bad radiator cap - replaced that - no change - same issue.
Then the thought came to me that the header was connected to the high pressure side of the cooling system - and when the engine was reved up it would cause the overflow.
I read through this forum -found another thread that this was the issue.
I reversed the hoses that connected between the pump and the outlet - and as of now it looks like that may have been the fix.
I will keep you updated - if anyone else is running into a similar issue i will be glad to share any other information i may get.
Keeping my fingers crossed that this is the issue.
Between this issue, and the fact that the disc brakes still have paper on the inside of the disk area below where the pads hit, i do not think the prior owner drove this at all. Hopefully i will have it sorted out soon and be able to put a few miles on.
Thanks again for everyone who has contributed to the forum - the information was really helpful. And again thanks Eric and Ralph for stopping by and giving a hand and great advice on Saturday.
Jesse
Jesse
