Just thinking out aloud here.
Way back there was a system used called CVT (I believe also known as DAF Variomatic) which used pullies that had a v cross section and the pulley side spacing was variable meaning the belts ran on an increasing or decreasing diameter meaning change of speed at the other pulley
I know on the old VW aircooled engines you set the belt tension in a similar way by clamping the fan pulley tighter forcing the belt further out. But this was a manual setting and not variable once the engine was running.
Has a system like this ever been developed for water pump and alternator pullies whereby the alternator and waterpump can be run at fairly constant RPM irrespective of engine RPM?
This, I imagine would be a big selling item on cars like ours where they are likely to see some high revs (possible WP cavitation) and yet will also see low speed work so permanent pulley diameter change is not that good an idea
