My McLeod internal slave cylinder started to leak so I installed new seals thinking this would solve my clutch hydraulic failure. No more leaks, good pedal for about 20 strokes, but then goes totally soft. Have bled the system several times. Master fluid reservoir never goes down (except when bleeding) and no fluid leaks anywhere. I'm thinking air leak with master cylinder seals? Don't know why this happened concurrently with the slave failure? Any advice before I dig into the front end on the SPF?
