Seymour Snerd
In case you are wondering, the worm-clamped connection between the two fuel tanks is a piece of 3/4" ID rubber hose on a welded-on and beaded 1" long 3/4" OD, 1/16"-wall stainless tube. If you don't like that connection you could cut/grind off the bead and should be able to put on a Parker 1210-6-12 AN compression fitting which gets you a 12AN male flare, and from there you could go to a 12AN hose end.
I haven't done this, but I might. Will report back if I do.
