But by far the best thing was the thick Lexan, firewall window, big improvement.
I still have the upgraded glass bulkhead window with thicker rubber edge seals available (hint, hint....shameless self promotion!)
I have about twenty of these out in the field on SPF 40s and have had good reports back.
I have downloaded an App called Sound Meter from Smart tools on my Droid. CAT uses the system in there equipment. I also have an NIST instrument here at the plant used for noise measurement in the environment, but haven't run a side by side comparison of the two. I feel the app may read a slightly higher reading than the NIST meter. If you want a baseline try the app out.
