For those who may not know, when you say 1.5" on the coolent lines that is the over all OD. People who may use pipe need to know that it is measured on the ID, Tubing on the OD. 1.5" pipe is 1.90" OD and Tubing is 1.5" OD. So if you were to use Pipe you would need to use 1.25" pipe as it would bring the OD" to 1.66" OD. Also if you choose pipe over tubing try to get it in Sch 5 or 10 it is a thinner wall and give's you a larger ID and will reduce weight if that is a concern.
Cheers,
