I just ordered my SL-C planning track car build. I'd like to keep it as lightweight as possible and select the correct options now.
1. Brakes. Planning stock brakes but would like to use 2 piece floating rotors as that would save about 5-9lb/corner.
Two-piece rotor (Open Slot) - CAMARO SS FRONT 10-11
Just wondering if anyone has tried this and exactly what rotors used.
2. Battery. I saved 20lbs of weight on my current track car (C6Z06) by using and inexpensive AGM battery. A lithium battery seems workable for about $400. and only 2lb. Braille Auto ML7-HPS Braille 12 Volt Micro-Lite Lithium Racing Battery
3. Wheels. I don't see much savings here as the CCWs are relatively light and strong and round. Some Z06 weights for comparison.
Z06 OEM and Aftermarket Parts Weight List - Corvette Forum
4. Steering column and rack. No Data but probably not much savings.
5. Engine selection. I like the LS3, 7, 9. I've read that the LS-9 is 72lbs heavier which seems unlikely but if true would be a deal breaker.
6. Lexan windshield. No data.
Other Ideas?
Mark
Other Ideas?
Mark
