I bled my brakes (Wilwoods) today - no leaks anywhere, no air left in the lines, and a rock solid pedal. However, it left me with 3 mysteries
1 - I can spin the tires by hand, however I can feel/hear a slight drag. I think this is okay since everything is brand new and has to bed in? (if I recall when I did my Cobra's Wilwoods, I had the same thing - initially a slight drag that went away after a few miles of driving)
2 - I've only got like 1'' of travel on my brake pedal after being fully bled. It's rock hard and holds pressure perfectly, and if I open a bleeder screw, the pedal sinks all the way down (with no air coming out), so I know that's good. But it feels more like an off/on switch because of the limited travel (about an inch worth of travel). Any thoughts on what could be causing this? I don't want the pedal to sink all the way down, but i would like some travel on it. I'm thinking the residual valves, but don't I need them since the master cylinders are below the calipers? Other than that, I don't know what could be restricting travel? For what it's worth, at the end of teh travel (e.g., 1'') the brakes are locked solid, but it's more like an off/on switch right now (no brake or full brake)
edit: the only thing I can possibly think of is this is how the manual brakes work in this car (as any googling references to no pedal travel indicate a failed pump, but not pumps here), but I'm not certain I buy that because my cobra is 6piston Wilwood manual brakes and the pedal has 'normal' amount of travel.
3 - Other than driving it, how can I tell if i have the balance bar setup to be 50/50?
