I searched the forum for information regarding fuel sender units for the Koso gauges, but came up empty handed.
I see that the Koso has a range of 100 ohms, and 510 ohms.
Albeit more pricy, is there any reason this unit wouldn't work?
RA9511-ISS - ISSPRO Inc.
I've measured the tank depth to be 27.9cm. The above unit is 11", and they only come in 1" increments. If I must use a 10" unit, will that cause calibration/display reading issues?
What fuel sender unit are you using?
