I was interested to see if anyone has regeared the Ricardo gearbox and if it can be done. I would like to gear the final drive where the car will only do 200 to 205. I can hit 160 mph in 4th and still have 5th and 6th to go. The problem I see is it takes a long time to run through 3rd 4th and 5th on the track. I am wondering if you can change a gear to reduce how long each gear will run out, IOW like changing the rear end in a standard car where all the gears are quicker but the transmission is still the same. It is nice to have the tall gears but when you never use them because there isn't enough straight away, then change the gearing so that at the end of the straight away you are just about tacked out in 6th and I think 200 or so on a road course in my street car will just about be fast enough, maybe a little faster though. Any thoughts
Bob D
Bob D
