Has anyone used or will be using an Audi transaxle? If so, do you think that the half-shaft angles would exceed 20 degrees if the engine was mounted at it's original height? I have found that you can get CV joints that will withstand up to a 20 degree angle. If this angle is not too bad would this be a solution?
Every transaxle has it's advantages and disadvantages. Looking at the Audi I see a good number of pros and some cons
Pros:
- Low cost
- 6 Speed (good ratios on some trannies)
- Easy to find
- O1E has been said to handle +500hp
- Light (65kg)
Cons:
- Half-Shaft Angles (unless you raise the engine)
Pros:
- Low cost
- Easy to find
- Light (65kg)
Cons:
