I'm trying to figure out how much someone could get done with an SLC build before not having the motor bolted in slows you down. I've contemplated purchasing the kit in stages. Trying to figure out an overall order of doing things....
I do have an engine/transaxle combo selected. LS7 and Graziano
How about this idea. You buy a used LS series engine for as cheap as possible. Use it as a basis for building out the engine room such as water lines, oil lines, motor mounts, exhaust system, and working out the mounting of the gearbox, clutch etc. Maybe the Texas guys can help with this with a modest deposit for the new engine to be delivered later if necessary. Hell the might have some old heads, block and other pieces to loan you. Ask...
Dave, I'm not sure if anyone has done a LS7/Graziano yet? You may want to check out the availability/cost of adapter plate and possible clearance issues with the length of the Grazziano; you may be in uncharted waters!
Just a thought.
Jim
I'm pretty sure Dave Forster has the LS7/Graziano setup in his SLC he is currently building. I'm lucky enough to live less than 30miles from him. His car will be the one I look at and say "Ohhh that's how that goes...."
That's what I was thinking Alex... I'm planning on buying a built turn key motor from Texas Speed And Performance. They have a one year warranty and I'm sure I will take more than a year to build this car.
It will cost more building in stages, and take longer. That extra could pay interest if you borrow for the major costs from the start. IMO, it avoids getting parts that might not work well together, or having to pay extra (plus time) for mock engines. There could be good reasons to buy the whole kit, but delay the engine and gearbox - something better may come along, or (engine) prices fall though.I'm trying to figure out how much someone could get done with an SLC build before not having the motor bolted in slows you down. I've contemplated purchasing the kit in stages. Trying to figure out an overall order of doing things....
<end quote in-part>
he is just very old.....:2thumbsup:...almost my age
