The info I've found on this trans states it takes about 3.8L of fluid. The question is: Since we flip the trans from it's normal orientation, should our fluid fill capacity change or stay the same. I don't have the trans in front of me to see if the side fill level hole is higher or lower when flipped and is the standard fill capacity set to make sure the internal gears are immersed to a set designed depth.
Additionally, fluid type: one could spend/waste a day reading opinions about fluid choices. I am currently using Swepco 201 fluid (API GL-5)- I believe it's a non-synthetic. Half the Porsche sites/forums seem to bounce between Swepco and then I see Mobil Delvac 75w-90 pop up all over the place-the mobil is a synthetic from what I understand.
Any thoughts on the above questions. BTW: my trans is using the OS Giken LSD unit. I have some fluid weep from the side axle seals but besides that no issues. The unit was rebuilt and bought from Gbox - should the seals be leaking already (approx. 1,400 miles).
Thx, Mike
Thx, Mike
