G
Guest
Guest
In the process of acquiring my water pump and starter. Was wondering what people are using?
Already have the transaxle. It's a G50 Porsche '90 and later. Apparently Tilton doesn't make a starter and the stock unit may not be enough for the 10/1 comp 302. Tilton does make a starter for the '89 and earlier G50. Does anyone know of a high torque aftermarket starter for the '90 and later G50? This may be something to look out for if your looking at a G50 t/axle.
Now the water pump. Because of close clearance at the front of the engine a shorter w/pump is needed. My friend with the real GT40 says his is a highly modified stock unit. Another builder says he used a '90 to '93 Tbird pump and front cover and gained 2 inches. There's also a company "snow white" that has a short w/pump kit, but it's spendy. What water pumps are being used other than stock?
One other quick question, I remember a thread in which one of the kit manufacturers was asking if anyone wanted a monocoque chassis or plans/drawings for one... was it RF?
