Hello again,
Beginner here.
Most of the kits I’m looking at come with Ford Granada front spindles and I’m assuming that this is not the same tank of a US Granada of the late 70’s and early 80’s. Instead of getting the overseas Granada spindles and having to retrofit or custom build a high performance disc brake setup, I am looking for spindles from off the shelf US applications that will allow me to use Wilwood brake components. If no off the shelf applications work I can go custom NASCAR (circle track) spindles.
Could I please ask a few of you to measure the dimensions of the spindles? I need height from the top of upper mounting point to the bottom of the lower mounting point. That is the most critical I think but feel free to throw any other measurements in that you would feel is necessary.
As far as the rear is concerned what has everyone else done? I gather from what I've read the rear uprights are all custom. Anyone have a pic of the rear upright with the rotor removed? I guess I will have to fab a rear bracket for Wilwood calipers.
Thank you for your time,
Shane Lowrance
Beginner here.
Shane Lowrance
