Can someone tell me some stuff?
I've been eyeing the idea of building my own frame (being engineering major and all
Can someone tell me the f/r tracks(1), wheelbase(2), and about the doors: how thick are they at the bottom(3)? how long are they at the bottom(4)? what's the vertical distance up from the lowest point of the car to the bottom of the door(5)? And also what's the horisontal distance between the lowest point of the door (rear bottom point of the door when looking at the car from the side) to the rear axle(6)?
That should be enough to get me started with general design and models.
Thanks a million in advance!!
Also, completely forgot, please include the tire sizes for front and rear
Thanks!
[ February 08, 2002: Message edited by: lev_kuznetsov ]
G
Guest
Guest
Lev, we need to talk,
I'm currently building a chassis from scratch that I designed and drew in autocad. It's loosely based on the KVA/Integrity/Sabre/??? chassis and measurements off a Mark V
the best sources for specs and such are
the englanders GT40 club site
http://www.gt40club.clara.net/
and ERA
http://www.erareplicas.com/gt/gt.htm
and (last but not least) this forum!!!
and don't forget the original forum this one started from
http://www.network54.com/Hide/Forum/127426
I tried to email you and it got kicked back??
[ February 08, 2002: Message edited by: Kalun D ]
Hi all
and here's one I made earlier!!!
[ February 09, 2002: Message edited by: Chris Melia ]
You might want to check the JW Automotive Engineering Book on GT40 Parts and Spares. I do not have the book, but George Cochran did fax me some info from the book when I needed some exploded drawings.
I do not know if the book is still produced, or where you might get one. But I would imagine some of our UK folks on here would know. It does have exploded drawings of pretty much the entire car.
Ron
Ron,
I have a copy of the J.W.A illustrared parts list. I think this is what your refering to. If you'd like I can copy it for you. It's not big but bound in such a way that it can't be taken apart so the copys maybe a little rough. I'll do the best I can with what I have.Just e-mail me and let me know.
ohn
Yep,
It is the illustrated parts list that John refers to. I don't need it, but the first fellow in the thread might be interested as he was looking for dimensions, they might be in there?
R
G
Guest
Guest
>Can someone tell me the f/r tracks(1), >wheelbase(2),
specs from Englanders site http://www.gt40club.clara.net/netintro.htm#Specs
don't forget track depends on tire width
>and about the doors: how thick are they at >the bottom(3)
KVA 7-1/2" door width, sill width KVA 10" original 13-1/2"
38" (KVA)
>what's the vertical distance up from the >lowest point of the car to the bottom of the >door(5)?
KVA and original 10" sill height
>And also what's the horisontal distance >between the lowest point of the door (rear >bottom point of the door when looking at the >car from the side) to the rear axle(6)?
29" to 30"
>Also, the tire sizes for front and rear
original see the site page above
Mark V
front 215/60-15
rear 255/60-15
my KVA
front 225/50-16 on 8"rim 5"bs
rear 255/50-16 on 9-1/2" rim 4-1/2"bs
you'll want to know your tire/wheel availability and backspacing before you start designing
