Robert, I’m glad you specified ‘fitting a road tyre onto it's widest DESIGNED rim. Mounting a tire on a rim wider than recommended by the TIRE MANUFACTURE can cause several problems including uneven tire wear( the outside tread edges will wear more than the inside tread, increased chance the tire will separate from the rim, decreased traction, and it just doesn’t look right. I have seen a M8F McLaren involved in a serious accident a few years ago because the rear tires were to narrow for the wheel. The tire’s centrifical force broke the bead seal whan the tire lost traction with the track (ever seen bead locks? they keep the wheel in the rim). My guess is a 335 is designed for a 12-13 inch wheel max. I always want my sidewalls to bow a bit past the wheel lip.
IMSA
