Lynn Larson brought up an interesting topic with respect to how to put a supercharger on a GT40. There may be some elegant solutions for those so inclined.
Remember the 3.8L Supercharged V6 motor that appeared in the Thunderbird SC from 89-95 (and Cougar XR7 for 90)? This was a successful application of the Eaton M90 supercharger nestled in the valley of the V6.
The motor used a special intake manifold that accepted the intake charge from the backside of the motor. The manifold was very flat so that the blower could sit on top of it. The motor had no distributor so that the drive snout of the Eaton was easily packaged.
If a similar manifold could be made for the SB Ford a similar blower package should be easily produced - the whole thing is certainly less overall height than Webers.
Ford EEC IV control should be easily accomplished since the blower can be fed through the MAF just as in the orignal application. The EFI 5.0 V8 systems are extremely adaptable so won't be problems there. In fact, the crank fired Explorer 5.0 system would be perfect.
Now, I've got an M90 around here and a V6 manifold should be easy to scare up for modeling purposes. How would one make a V8 manifold - make a clay model first then???
Drive on the M90 would have to be longer but the Magnesoun (spelling) company that rebuilds Eaton units have a lot of different drives available that bolt on, I've used them before.
Interest?
R
Interest?
R
