I have a KVA bodoed car (I think) which is moulded to suit the old type 'Triumph Herald/Spitfire' over centre catches. These are unreliable and I wish to fill in these apertures and fit an alternative set of external catches. What is the correct method for doing this ? Should I use fibreglass matt and resin at the back and then use the premixed paste with the fibre in it to fill the hole flush from the outside ? Should I grind the surfaces to ensure good adhesion and what should I use as a finisher ? Is standard cataloy acceptable ? As you can tell........I am a bit of a fibreglass virgin !
Are there any decent books that you would recommend on car body work or working in GRP ? I don't want to complete the job and then find that it all starts cracking and falling apart in two months time.
Thanks guys.
Thanks guys.
