access
Dave Bilyk
Dave Bilyk
I think you have to use the search facility.
I get ' There have been no posts in the last 1 days in this forum. Try using the controls below to search for any older posts that may exist.'
edit; I just saw that if I go down to Display Options, I can change from the default 1 day to options going back weeks / months /years / beginning.
Does that help?
Thanks Dave,
I don't have any trouble getting into the other tech lines, like body, engine... I just click on the forum I want to visit and it open showing the last post and all before it to the bottom of the page. I also don't see any Display Options anywhere on the page. There is a Display Modes but changing those has done no good.
There is nothing that will prevent you from accessing that forum. I suspect it is your settings in your User CP.
Click User CP on the left of the upper menu bar.
Click Edit Options under Settings and Options
Select Linear Newest First under Thread Display Mode
Select 100 posts per Page under Thread Display Mode
Select Show All Threads under Thread Display Mode
That should do it.
Yep what Ron said...
It's tripped up more than a few people...
I use an iPad most of the time and have inadvertently touched and changed a setting..
