Quick question...
Can someone tell the part number of the pump that comes in the RamLift kit?
I bought one about 2 years ago (old pump). Since then, Simon has started using a different pump that lifts the car in 3 seconds as opposed to 8 or 9 seconds. I was wondering whether anyone here had received a lift kit recently, and would mind letting me know the maker and part number of the pump.
Also, I seem to have a some trouble with the fluid leaking out of the reservoir at the clamp. Since this is plastic, I'm trying not to over-tighten it, yet still stop the leak. So far, I'm not having much luck. Can anyone recommend a decent reservoir that will be less likely to leak?
I appreciate any help that you can provide.
Thanks,
Thanks,
