Is it me, or does the clutch pedal ms rod not allow for enough adjustment to align correctly with the accelorator and brake pedals? The brake pedal ms rods can be adjust far enough back where they are only a few inches in front of the accelorator (like a normal production car).
However, the clutch rod insert does not allow the rod to adjust far enough where it is not 4 or more inches forward of the accelorator. To make the clutch and brake pedal even, I had to remove about an inch off the clutch rod, otherwise all three were at different locations.
