I had the same issue. I cut the notches out of the dash for the roll bar so I could put the dash into position, and thankfully the column wasn't lined up with the instrument binnacle. So I moved the column to the left, centered it to the instruments, and it feels perfect when I sit in the seats. The seat is still as far to the center as it can go (without interfering with anything...) and my feet are angled to the center line of the car, as Fran says. I have the adjustable pedals, and the plate is also angled so when the pedals move fore/aft, they stay centered to the driver.
I also shortened the aluminum hex spacers on the bottom side of the dash to allow the column to rise as much as possible. It is now barely clears the aluminum chassis support. In my seating arrangement, the top of the 320mm steering wheel was blocking the gauges. Moving the column up gives you more freedom to use the column tilt. There are going to be consequences later with the column cover since I took up that room, but I'll gladly chop that up later to accommodate the improved visibility.
I don't know if this matters, but I also removed the stalks from my column. I'm not going to use them.
A.J.
