I have been looking for a 5000 OHM-1/4 watt resistor to work with the KOSO Dash Meter. I have found 1/4w 5100 ohms resistor and a 1/4 w 4.7K ohms resistor. Can any of these work?
My mistake it should have read tach. But the question is the same. Can I use a 5.1K or a 4.7K 1/4 watt resistor? Or can someone tell me where to look for a 5K ohm resistor? Radio Shack and Mouser do not carry them.
Or use a 4.7K resistor. The resistance requirement is approximate, so there is a little wiggle room. I am running a 4.7K resistor, and it, and other crate motors that used the same value, have been rock solid for the tach output.
