So has anyone done an electric ac compressor? If so, what comp did you use and how was the performance?
I am really starting to lean this way since my battery is in front also (to pull the large power lines from), and it would keep all of the plumbing relatively easy and on just one end of the car instead of almost literally running the full circumference of it! I will also be running a 200amp alt, so I should have plenty of extra power to run it.
I have been looking at the Prius compressors, but, it has a second plug outside of plain power and I have no idea how they would need to be controlled outside of a simple on/off.
Ideas?
Ideas?
