Go Back   GT40s.com > > >
The SLC Clubhouse RCR SLC Build Logs and Technical Questions
Thread Tools Display Modes
Old 2nd April 2016, 05:09 PM   #61
Fran Hall RCR
gt40fran's Avatar
gt40fran
I Have No Life
GT40: RCR
Re: Mark's GT-R Build
It most certainly will Mark
The 1500hp SLC proves that
gt40fran is offline   Reply With Quote
Old 5th April 2016, 01:34 PM   #62
mksetter
Silver Supporter
GT40: GT-R
In a previous post(#36) Luke showed the K & N cold air filter/ intake, and it was pointed out that it is good for about 250 to 350 hp. I have a dual throttle body set up and it looks like the motor will be around 600hp. Would a pair of these work? They look great and will fit on the throttle bodies after the custom adapters. I think I could run the tubing right up to the air inlets in the "B" pillars, and with a little fiberglass work, could make a sweet cold air intake setup. Any comments?
mksetter is offline   Reply With Quote
Old 26th May 2016, 07:40 AM   #63
mksetter
Silver Supporter
GT40: GT-R
I just got word that the GT-R is ready to ship and should be arriving here in Naples on June 5th. The crazy thing is that I have a 2 month motor home trip planned with departure the day after the car gets here. At least I will get to see it.
I have been working on the final stages of my garage, with the "Car Bar" being the last project. The bar is in. Working on the rock veneer for the back wall and the front of the bar. Lighting, plumbing and AV, then it is finished. Just in time for the car to get here.
Old 26th May 2016, 07:42 AM   #64
mksetter
Silver Supporter
GT40: GT-R
Some photos of the bar. Car pics to soon follow
Mark's GT-R Build-car-bar-construction-2-jpg   Mark's GT-R Build-car-bar-construction-jpg
Old 26th May 2016, 12:12 PM   #65
Tom
TomIsaacson
2 Tenths
It needs some beer taps!
TomIsaacson is offline   Reply With Quote
Old 26th May 2016, 01:19 PM   #66
LBCportagee
4 Tenths
I was considering these intakes for my LS1 build but I had some concerns about them. I'd say with a Katech LS3 and cross-ram intake with dual throttle bodies, these filter/intakes will be limiting your airflow at high RPM. That 350 hp is for turbo engines. 250 hp NA. If you took advantage of a ram air effect maybe you could be closer to 300, but you wouldn't be forcing as much air as a turbo for sure. Take a look at the filter. I think you would need more surface area. This is at 47 sq in. There are calculators out there to determine requirements. You can compare to your heads/intake combination CFM.
LBCportagee is offline   Reply With Quote
Old 27th May 2016, 07:54 AM   #67
rumbles's Avatar
rumbles
6 Tenths
I have a bone stock LS3, with just the one stock throttle body. I tried a K&N filter that was just a tad larger than the one in your PIC and it was too restrictive. In fact, it caused a “Fuel rich mixture” ODBII code. I swapped it for a much larger filter and the ODBII codes went away.
You can just barely see the filter in this PIC. Sorry its the only PIC of the filter I could find. The filter is near the center air vents, so I fabricated a top for it to keep most of the rain out of the intake.
Mark's GT-R Build-slc-john-connor-8-small-jpg
rumbles is offline   Reply With Quote
Old 5th June 2016, 09:56 PM   #68
mksetter
Silver Supporter
GT40: GT-R
I have everything finished in the "Car Bar" except the lighting. As you can see, I cut out a wall in what was once an office, then changed the ceiling so I could store parts in the "loft." Added a bar, seating, some rock wall accents and pictures. Now ready for the "arrival" party. Just don't know when that will be.
Mark's GT-R Build-img_2184-jpg   Mark's GT-R Build-img_2176-jpg
Old 5th June 2016, 10:00 PM   #69
mksetter
Silver Supporter
GT40: GT-R
Thanks, Guys, for the info on the air filter. I can see that I need to speak to the guys at K&N and see if they can help with a solution. I want to make use of the 'B' pillar air ducts, if I can. Hot air is a problem for mid engine cars. Hopefully can find the right answer. Again, thanks for you info.
Old 5th June 2016, 11:17 PM   #70
Scott R.'s Avatar
Scott R.
GT40: SL-C
Very cool! Very nice 458 Spider too!
SLC #000.5 (The first prototype)
4.0 Lexus V8 Twin turbo
Scott R. is offline   Reply With Quote
Old 4th August 2016, 06:26 PM   #71
mksetter
Silver Supporter
GT40: GT-R
I finally got the call. My GT-R is on the transporter headed to Florida. I am traveling, but will fly down on Monday to see the delivery. I won't be able to actually start the build until October due to travel plans, but will get some pictures to get this build finally started.
Old 13th August 2016, 10:19 PM   #72
mksetter
Silver Supporter
GT40: GT-R
The car finally arrived, so this officially starts the build. Before I go into any details, I would like to thank Dean, Allen, Will, Howard, Scott, and all of the others who contribute to this forum. Without your help, I would be on the side lines looking at others builds.
Also want to thank Fran Hall for developing such an awesome car.
My car arrived without any real problems, other than a small chip in the front splitter. The driver admitted it was his fault and would have to pay out of his pocket to get it fixed, but I am doing this for the fun and experience of the build, so I will repair and paint the splitter at some point.
Mannix Automotive is next to me in our business park condo, and those guys have been looking forward to the car arriving almost as much as I have. They helped unload and get it in the shop. After we stared at it from almost every angle, it was time to start removing some of the body.
Mark's GT-R Build-dsc00710_zpsdiqy8zeq-jpg   Mark's GT-R Build-img_2578_zpsqx8fkfqi-jpg   Mark's GT-R Build-dsc00714_zpsojjmak1n-jpg   Mark's GT-R Build-img_2586_zpslrosepu3-jpg
Old 13th August 2016, 10:31 PM   #73
mksetter
Silver Supporter
GT40: GT-R
While I was waiting for the car to arrive, I built some wheel dollys and two body carts. I had no idea what dimensions to make the carts. Just used some of the measurements from other cars. The front fit with little modification, having a horizontal support contact under the headlight boxes where there is some vertical support. I tied the sides together where there were locator pins, as you can see just ahead of the wheel well. The rear made contact where there was, again, adjacent vertical support. The carts are on casters, and high enough to be able to work on them when it is time for paint prep.
Mark's GT-R Build-dsc00730_zpsazojmorg-jpg   Mark's GT-R Build-dsc00729_zps4fyrgi0i-jpg   Mark's GT-R Build-dsc00728_zpsyq4azy7t-jpg   Mark's GT-R Build-dsc00732_zpsn5ohajzt-jpg   Mark's GT-R Build-dsc00733_zpscgm9uf0z-jpg
Mark's GT-R Build-dsc00731_zpsxldypf2f-jpg
Old 13th August 2016, 10:42 PM   #74
mksetter
Silver Supporter
GT40: GT-R
The rear clam also fit rather well, with minor modifications to the body cart. We wanted to limit the spread of the body panels, and there is a groove in the mating body panel that the clam fits into, so we used two pieces of wood to make the "groove" in the cart. Keeping the body shape the same as it was on the car was the priority. The support areas contacted the rear clam only where there are adjacent vertical body material.
Mark's GT-R Build-dsc00734_zpseaeavpwi-jpg   Mark's GT-R Build-dsc00735_zps5spfthpf-jpg   Mark's GT-R Build-dsc00736_zpstp9knrkz-jpg   Mark's GT-R Build-dsc00739_zpsdgvvdi5o-jpg   Mark's GT-R Build-dsc00742_zpsxrgapzlr-jpg
Mark's GT-R Build-img_2599_zpsuxrskorb-jpg
Old 13th August 2016, 10:51 PM   #75
mksetter
Silver Supporter
GT40: GT-R
After the carts were made, it was time to use the little I beam hoist that I put in to get the carts and the body parts up to the loft I use as a storage area. As I remove parts, tires, etc., they will go up to the loft until needed. Keeps the main floor clear.
Mark's GT-R Build-dsc00746_zps02xlknln-jpg   Mark's GT-R Build-img_2590_zpsngttu4aj-jpg   Mark's GT-R Build-dsc00745_zps6cflpvtf-jpg
Old 13th August 2016, 11:07 PM   #76
mksetter
Silver Supporter
GT40: GT-R
With some of the body removed, it was time to put the car up on the hoist and look around. The car is so low, I had to use a jack to lift the car enough to get the hoist arms underneath to the areas on the car that will support the lift. Some photos show the awesome suspension, engine and transaxle mounts. The motor looks just as I was hoping it would look. This is going to be a street car. I hope to take it on the Hot Rod Magazine Power Tour. It will look great.
To get this manifold to fit, we needed some custom throttle body adapters and needed the firewall modified. The boxing in the firewall and adapter can be seen in the close up.
I assembled the pedals and master cylinders, just to fill in some time. I am leaving for a month for family (grandchildren's birthdays) and overseas travel (kayaking and hiking in Greece), but will be back in October to get back at it.
As others have mentioned, please feel free to add any comments or errors you see I might be making. This is my first time doing anything like this. I worked on my 1971 Ford Pinto to keep I running and my 1977 Corvette to keep the costs low, bit that was back in college. Now I am retired and getting back in it with this project. I welcome your comments and suggestions.
Mark's GT-R Build-dsc00747_zps7kknvpyz-jpg   Mark's GT-R Build-dsc00741_zpstbzzjaa1-jpg   Mark's GT-R Build-img_2593_zpsqotxmepu-jpg   Mark's GT-R Build-img_2592_zpsfrhxhjxf-jpg   Mark's GT-R Build-img_2594_zpsnw4l9rg6-jpg
Mark's GT-R Build-img_2595_zpscjegeppp-jpg
Old 14th August 2016, 06:12 AM   #77
albanygt40's Avatar
albanygt40
Wow that looks cool.
RF GT40
Pantera #3646
albanygt40 is offline   Reply With Quote
Old 14th August 2016, 09:04 AM   #78
Mike Giblin
Gold Supporter
GT40: SL GT-R #9
Mark, Looks Great!! Congratulations, Mike
Mike Giblin is offline   Reply With Quote
Old 14th August 2016, 05:17 PM   #79
Dlampe's Avatar
Dlampe
That looks awesome! I can't wait to see your build.
Dlampe is offline   Reply With Quote
Old 14th August 2016, 06:54 PM   #80
dallas_
Silver Supporter
GT40: SL-C
Mark,
I saw your car in Fran's shop a few weeks ago when I picked mine up. Really impressive. I'm sure you will have a great time getting it finished up and on the road.
dallas_ is offline   Reply With Quote
Forum Jump
