Thought I had it solved, and then I didn't. Working to install the front inner fenders and discovered by conventional wisdom I need to move the splitter brace.
Now I am looking for techniques you used to run the headlight harness from the inner front inner radiator area, thru/over the aluminum side walls and past the nose vertical fiberglass support walls that allow you to lift/raise the nose off, and still have front inner fender wells installed.
I thought I saw some cleaver quick disconnect ideas but have never seen the wheel wells, nose, harness combinations all at once. I do not plan to design a rotating nose section, so I presume the standard design is to lift it off to gain access to the front nose section area for servicing.
Need some help here........stumped.
