When I purchased my car secondhand it came with a set of well made stainless steel tubes from the engine to the radiator. Now that I'm at the point of finalizing the cooling system I realized the tubes are backwards. The radiator outlet is at the top of the rad. The issue being any steam/ gases at the top of the radiator could cause water pump cavitation as it draws from that point. Question- With a closed system where the rad has a steam port bleed at the top of the inlet sides tank (to the higher coolant tank) should I be concerned about the water pump suffering cavitation? Does anyone have any experience with this? Opinions on the internet are all over the place. The car will mainly be used on the street but with some tracks days during the year. And if this is a problem should I a) Bite the bullet and have the rad ports reversed and re pipe b) install an electric booster pump c) put the car in my living room and don't worry about it (lol)
