Fuel fill hose
Does anyone have a part number and source handy for the fuel filler hose connecting the tank to fuel door? Thanks!
Thanks Ron...... The bumper you developed from the Ford GT has been shipped and I should have it in a day or so. Thanks for all of your help.
Cam I hope this helps you. This fuel fill hose has a molded 90 deg bend and can be cut each side of the bend and with the 45 deg hose will make a very neat installation.
<style type="text/css">p { margin-bottom: 0.1in; direction: ltr; color: rgb(0, 0, 0); line-height: 120%; text-align: left; }p.western { font-family: "Liberation Serif",serif; font-size: 12pt; }p.cjk { font-family: "Liberation Serif"; font-size: 12pt; }p.ctl { font-family: "Liberation Serif"; font-size: 12pt; }a.western:link { }a.cjk:link { }</style>
https://www.summitracing.com/int/parts/cel-59207
with:
https://www.summitracing.com/int/parts/cel-59202/overview/
The sparco fuel fill assembly is 2.25" OD vs the tank's 2" OD inlet so you'll need some kind of transition between two. A lot of folks are using this combo:
90 degree fuel fill hose elbow Gates 24717
45 deg Gates 24713
2" to 2.25" exh adapter ROI 548543 All auto zone or walker (summit) 41700
Personally I used the 90 elbow and welded up a 45* stainless transition piece with this straight section to finish it off:
2.25" I.D. Black Filler Hose, per foot - Pegasus Auto Racing Supplies
I still have some of that left over if you're interested. Only used about 4" of it
