19th November 2006, 10:52 AM
#1 (permalink)
| | Paul Champlin Rookie
| Registration ????'s Since it is delivered as a roller, would you still have to go through SB 100 (I'm in California) to get it registered or can it get around that to get a VIN #?
TIA,
Paul
__________________ FFR Cobra, Ultima GTR, 68 Camaro SS, 99 Spec Miata |
19th November 2006, 10:58 AM
#2 (permalink)
| | Bill D I Have No Life
| Re: Registration ????'s Paul-
If you want to avoid having to load the car with current yer smog equipment, you will have to go through the SB100 route. I received a roller from RCR and plan to be in line Jan 2nd for my SB100 #
BTW - I had an FFR Cobra too |
19th November 2006, 11:03 AM
#3 (permalink)
| Re: Registration ????'s Hey Bill,
Yeah I've tracked your progress on the other forum. You're doing a great job in your build. I suspected I'd need to still do the SB 100 thing, but wasn't sure if receiving a roller, changed any of those requirements.
Thanks,
Paul
19th November 2006, 11:33 AM
#4 (permalink)
| | David Briggs 6 Tenths
Join Date: Apr 2004 Location: San Diego GT40: SPF MKI #2214
| Re: Registration ????'s Your car needs to be running, CHP has to verify Vin #, Referee Station has to run a smog check on the car to Issue exemption, you need a Brake and Lamp certification. Immediately contact DMV to get the necessary forms and get a Temporary operating permit. If you are standing in line on the 1st business day of the year you will probably not get a certificate, you need someone in the DMV on the phone to Sacramento to give you the best chance.
__________________ SPF MKI #2214, 65 R model clone, 67 Al Craft Indy Car, 10 Genesis Track Coupe, 02 Lightning |
19th November 2006, 02:02 PM
#5 (permalink)
| | huntsen 7 Tenths
Join Date: Oct 2003 Location: High Wycombe, U GT40: Factory-blt GTD
| Re: Registration ????'s Quote: |
Originally Posted by 561234 Your car needs to be running, CHP has to verify Vin #, Referee Station has to run a smog check on the car to Issue exemption, you need a Brake and Lamp certification. Immediately contact DMV to get the necessary forms and get a Temporary operating permit. If you are standing in line on the 1st business day of the year you will probably not get a certificate, you need someone in the DMV on the phone to Sacramento to give you the best chance. | I thought the UK SVA was bad enough, but this is bureaucracy gone mad!
__________________ Editor Fortyfication, GT40 Enthusiasts Club |
19th November 2006, 02:24 PM
#6 (permalink)
| | Ron Earp Administrator
| Re: Registration ????'s Paul, as far as I'm aware from reading the Cobra boards for a long time, and hearing about people here, it really makes no difference if the car is a roller or a box of parts. To the DMV it isn't a "production" car and in about all states follow the speciality construction car rules, i.e., kit car registration.
The reason Superformance, CAV, and others import the cars into the US and installs the drivetrain here is that by doing so they avoid all the red tape with importing an automobile. A rolling chassis doesn't fall under those restrictions that an automobile would.
__________________ Ron Earp To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
19th November 2006, 04:04 PM
#7 (permalink)
| | car guy A Tenth
Join Date: Dec 2005 Location: San Diego, CA GT40: Bailey Edwards
Saw your post and thought I should contact you. I too live in San Diego (Carmel Valley), also have a FFR Cobra and just registered my GT40...so I could give you some hints to guide you through the process. I'd love to talk cars with you. Please give me a call. Thanks.
Larry Lessie
858-481-1586
858-705-1912, cell |
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/superformance-gt40s/19884-registration-s.html | | Posted By | For | Type | Date | | GT40s.com | This thread | Refback | 19th November 2006 10:57 AM | |
