Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 01-01-07, 12:55 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Moveover
Rep Power: 2 Moveover is on a distinguished road
Smile Alternator Clearance Issue
Anyone know if Hi-Tech has addressed the issue on the SPE GT 40 re the alternator hitting the cockpit panel when a Roush engine is installed that has the alternator and AC comp. mounted at the lower right of engine?
Also, I am interested in issues others have had with the supplied trans brackets for the shift cables on the ZF-2.
Thanks for any help.
Moveover is offline
Old 01-01-07, 11:17 PM   #2 (permalink)
Bigblockquad
GT40: SPF GT
Rep Power: 3 Bigblockquad is just really nice
Re: Alternator Clearance Issue
Trond,
I have a question. Does the alternator come into contact with the bulkhead (cockpit wall) when idling or under normal driving. If not can a change in motor mounts be made ie, different limiters allowing less travel of the rubber mounts or maybe a poly motor mount.
I'm assuming with the roush motor your using the roush serpantine belt system and if so can the alternator be adjusted down and use a slightly longer belt?
My car should be here in May and yours is not the first I've heard of this problem. I'd just like to have a fix before the car arrives.
BTW a large part of my family still lives in Norway. Where abouts are you?
Rich.
Bigblockquad is offline
Old 01-02-07, 01:16 PM   #3 (permalink)
daryl adams's Avatar
daryl adams
Silver Supporter
GT40: SPF MKI P2123
Rep Power: 0 daryl adams has a little shameless behaviour in the past
I think Rich is on the right track here. My Mangusta had the same problem with pulleys making contact under hard acceleration. I rebuilt the motor mounts to use a through-bolt and an anti-uplift cushion and the problem went away. I'm sure Dennis Olthoff is on top of this one.
Daryl Adams
Superformance GT40 MKI P2123
'73 246 Dino Spyder
'69 DeTomaso Mangusta
'68 Lamborghini Espada
SCCA Spec Racer Ford
daryl adams is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/superformance-gt40s/20321-alternator-clearance-issue.html
Posted By For Type Date
GT40s.com This thread Refback 01-01-07 01:14 PM
