Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 01-20-08, 03:36 AM   #1 (permalink)
Bigblockquad
GT40: SPF GT
Rep Power: 2 Bigblockquad is just really nice
Oil temperature?
What oil temps are you guys seeing? Drove the car today and it was fairly cool out. I never saw the oil temp go much over 50 degrees celsius. Is that normal? I would've at least liked to see a temp near 100 degrees celsius.
Thanks in advance
Rich.
Bigblockquad is offline
Old 01-20-08, 09:03 AM   #2 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 6 steve c has a spectacular aura about
Re: Oil temperature?
Rich,
I like 80C H2o and 80 min to 90C oil.
Steve
steve c is offline
Old 01-20-08, 09:37 AM   #3 (permalink)
2124's Avatar
2124
5 Tenths
GT40: Rescue, CA
Rep Power: 10 2124 is a glorious beacon of light
Did the same thing today and the oil temps were similar - not much above 50C.....
CAV #80, 331 Keith Craft, RBT Swift DB5
2124 is offline
Old 01-20-08, 09:44 AM   #4 (permalink)
chuck 1's Avatar
chuck 1
7 Tenths
GT40: CAV
I had to wrap my oil cooler in insulation for most of the year except summer to achieve decent oil temps.
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is online now
Old 01-21-08, 12:35 AM   #5 (permalink)
561234's Avatar
561234
GT40: CAV #56 347, we
Rep Power: 8 561234 will become famous soon enough
Cool Re: Oil temperature?
I am not certain that the temp senders supplied by CAV were correct for the VDO gauges installed in the pre 100 cars. My oil pressure read backwards, my coolant always reads very low, oil temp did get pretty hot in a track session early on but I have since installed an oil cooler with a thermostat and now I don't see much oil temp either.
I did contact VDO and was able to get the correct oil pressure sender, it was quite different than what came with the car.
Dave
Cav GT 40, 02 Lightning, 65 R model clone, 66 Al Craft Indy Car, 03 SL 500, 03 Triumph Bonneville.
561234 is offline
Old 01-21-08, 01:43 AM   #6 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: KVA body, scrat
Rep Power: 10 Kalun_D will become famous soon enough
Originally Posted by 561234 View Post
....but I have since installed an oil cooler with a thermostat and now I don't see much oil temp either.
Dave
Is that a mechanical thermostat? How does it control oil cooling? Does it bypass the cooler?
Kalun_D is offline
