Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 04-09-08, 01:23 AM   #1 (permalink)
SwiftDB4
Rep Power: 2 SwiftDB4 is on a distinguished road
A/C Hookup
Need advice from anyone with a Roush engine with serpentine belt. It uses a Sanden 7176 compressor with side ports, not the earlier 508 model with rear ports. The supplied A/C hose fitting goes under the compressor, but I can't hook up both hoses in that location. Options seem to be getting adapters for right side hookup or replacing one of the hoses with a shorter custom one. I think Spyder Mike has the later compressor. Can someone post a photo or help me out? Thanks.
SwiftDB4 is offline
Old 04-09-08, 08:49 AM   #2 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 18 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: A/C Hookup
Don't know if it is much help to you. I have been facing the same issue and created my own AC Compressor Bracket that should get me out of the woods...
AC Compressor / lines question
I'll be making a template to scan into a PDF so the brackets can be easily re-produced soon..
Regards - Randy
Big-Foot is offline
Old 04-09-08, 11:21 AM   #3 (permalink)
SwiftDB4
Re: A/C Hookup
Thanks Randy. My compressor is on the right side and I don't want to redo the elaborate Roush bracketry. I'm hoping to hear from another SPF owner that has the same compressor/port location.
SwiftDB4 is offline
Old 04-09-08, 06:10 PM   #4 (permalink)
P2164's Avatar
P2164
GT40: SPF 2164 07-07
Rep Power: 3 P2164 is on a distinguished road
Re: A/C Hookup
Dave I have a SPF MK1 with a aluminum block but used the brackets that came with the car, not that I wouldn't like to have had the Roush set up but this car is eating me alive. I cut about 1.5 feet of hose off and crimped new fittings on them, you may be able to find some different ones on line that will lessen the distance between the engine bay and compressor. Here is a picture of my set up and another picture of what I believe to be your set up.
P2164 is offline
Old 04-14-08, 01:51 PM   #5 (permalink)
Team Jeff
GT40: Superformance
Rep Power: 2 Team Jeff is on a distinguished road
Re: A/C Hookup
#2109 has the Roush motor & I believe the same compressor you have. It is side port and uses a billet adapter that says True trac on it. The manufacture calls it an A/C manifold here;
Billet Specialties - Ford Small Block Serpentine with A/C
If you still need photos let me know.
Team Jeff is offline
