Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 04-23-08, 12:10 PM   #1 (permalink)
DonWheeler's Avatar
DonWheeler
GT40: Superformance
Rep Power: 2 DonWheeler is on a distinguished road
Defective Turn Signal Switch
I took delivery of 2171 on April 7th. I'm having difficulty getting the vehicle inspected due to a defective turn signal swith that blows the 6th fuse in the fuse panel. I'm working with my dealer to resolve the issue, however, a faster resolution might be to purchase a replacement switch on my own.
The brand name of the switch is Hella. Can any one tell me where I can locate and purchase an exact Hella replacement, or an aftermarket turn signal switch that performs the same functions as the original?
Thanks,
Don
Don Wheeler
Cobra - Lightning - SPF GT40 MK2
DonWheeler is offline
Old 04-23-08, 03:04 PM   #2 (permalink)
crossle43
GT40: RCR40 #27
Rep Power: 7 crossle43 is on a distinguished road
Re: Defective Turn Signal Switch
Don,
Depending on the wiring, you may not need a new switch. Troubleshooting the circuit should settle that real quick.
When you discover the cause, let us know what you found.
Best,
T.
Every job is a self-portrait of the person who does it... autograph your work with excellence - unknown
crossle43 is online now
Old 04-23-08, 03:05 PM   #3 (permalink)
SpyderMike's Avatar
5 Tenths
GT40: So Cal
I have a very dim turn signal light on my car....I wonder how that harness is routed...
SpyderMike is offline
Old 04-23-08, 07:50 PM   #4 (permalink)
P2164's Avatar
P2164
GT40: SPF 2164 07-07
Rep Power: 3 P2164 is on a distinguished road
I agree! Don't change the switch! Its more than likely a problem at the termination points of the wires (bulbs). I would unplug front harness first and see what happens then the rear, isolate it to front or back then go from there. Mike check your ground points and also the socket for the bulbs.
P2164 is offline
Old 04-23-08, 08:42 PM   #5 (permalink)
SpyderMike's Avatar
5 Tenths
GT40: So Cal
I will next time I am alone with the car...
