Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 05-27-08, 11:43 PM   #21 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 7 steve c has a spectacular aura about
Re: Upgrades/options and mods to P2125
Victors,
CC3251
Steve
steve c is offline
Old 05-28-08, 08:17 AM   #22 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Steve,
Your setup sounds right. Guess I didn't read correctly. Did you wire the bypass directly to the ignition switch? I am thinking of wiring mine to a momentary switch that has to be thrown in order for the pumps to run and car to start. If not depressed/flipped, the fuel pumps will not work. The switch will be in a non dash location. Sort of an anti theft setup. This may be a moot sort of thing if the turn over pressure exceeds the pressure switch.
DRB#5
wbmusarra is offline
Old 05-29-08, 09:45 AM   #23 (permalink)
steve c
Steve
Bill,
Low oil pressure switch wired to fuel pump relay.
Why not wire a hidden "security" switch into the ignition switch ?
steve c is offline
