Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 22nd July 2008, 07:09 PM   #1 (permalink)
SwiftDB4
GT40: SPF P2226
Roush oil pressure
Wanted to know from other SPF owners what oil pressure they get with a Roush engine? My new 427SR is 55psi cold, but drops to 45psi at 80 degree C. The 45 psi is from above idle to 3500rpm when it slowly moves up to 50psi. I'm using conventional 10-30 Pennzoil as recommended by Roush for break in.
SwiftDB4 is offline
Old 22nd July 2008, 07:26 PM   #2 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
Re: Roush oil pressure
about the same, and that should be fine. I use Royal Purple synthetic, 10w 40
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is offline
Old 23rd July 2008, 12:57 AM   #3 (permalink)
Mike Drew's Avatar
Mike Drew
GT40: None, yet!
High oil pressure can be a bad thing. The oil pump is driven by the camshaft. The gear on the distributor turns the distributor up top, and the oil pump down below. A high-pressure pump puts additional strain on the gear, which is held to the shaft with a shear pin. Eventually the strain can become too great, and the shear pin does what it's supposed to do (shears) leaving you with no oil pressure, no distributor, and a dead car.
Additionally, too-high oil pressure can blow cheap filters apart which creates a hell of a mess at best, and at worst can oil down your tires and send you backwards into the trees.
Both my Pantera and GT350 clone were built with high-pressure oil pumps, and deliver 70+ psi all the time. The GT350 will generate 100 psi when cold, until the oil warms up. This is decidedly a bad thing in my view, and since that engine is being rebuilt, the pump is being changed to a standard one to give a more-desirable figure, such as 50 psi.
Be happy with what you've got.
Mike Drew, Vacaville, CA (
'72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1....
Mike Drew is offline
Similar Threads
New 'Roush' for my MK IV jac mac GT40 Tech - Engines/Induction/Exhaust 20 26th September 2007 12:08 PM
Roush Engines SpyderMike GT40 Tech - Engines/Induction/Exhaust 17 5th September 2007 06:43 PM
Roush Air Filter HUW PEPLOW The World Market - Share Parts, Sources, and Reviews 0 8th April 2007 07:02 AM
Roush SBF 427 on eBay llarsen The World Market - Share Parts, Sources, and Reviews 0 29th August 2005 02:27 PM
Roush Intake llarsen GT40 Tech - Engines/Induction/Exhaust 8 31st December 2003 12:18 PM
