Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Superformance GT40s
Superformance GT40s Sponsored by Superformance.
Old 4th June 2010, 09:36 AM   #1 (permalink)
Jim
fearsom
Wheel backspace
Can anyone tell me what the backspacing is on the Superfomance Halibrand wheels?
fearsom is offline
Old 4th June 2010, 10:22 AM   #2 (permalink)
Mark IV's Avatar
Mark IV
Sponsoring Vendor
GT40: Superformance
Re: Wheel backspace
I have a set on the ground off P2270 right now. I will measure them and post for you.
The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get...
Mark IV is offline
Old 4th June 2010, 10:47 AM   #3 (permalink)
Jim
fearsom
Re: Wheel backspace
Thanks I really appreciate your effort. Jim Fletcher
fearsom is offline
Old 5th June 2010, 02:44 PM   #4 (permalink)
Mark IV's Avatar
Mark IV
Sponsoring Vendor
GT40: Superformance
Re: Wheel backspace
Front and rear are 3.75" backspace for the Halibrand type aluminum wheel.
Mark IV is offline
Old 5th June 2010, 05:27 PM   #5 (permalink)
Jim
fearsom
Re: Wheel backspace
Thanks For checking and posting Jim
fearsom is offline
Old 20th June 2010, 06:37 PM   #6 (permalink)
kcoffield's Avatar
kcoffield
GT40: SPF P2174
Re: Wheel backspace
I made an unusal discovery today while doing some wheel bearing maintenance and have a question related to this thread:
I had previously noticed one pin drive spinner snout that was slightly shy of flush (front passenger side) on P2174 while the other three were about ¼” proud when the wheels were seated. I measured the pin drive snouts and they were the same. So I measure the back spacing on the wheels and found one is 3.75” and the other is 4.25”! See attached picture. This makes a very noticeable difference in where they run in the wheel well. They are 6 pin Vintage Wheels HA17s. The fronts are 17x8.5. They were on the car when I bought it and these wheels and were purchased and installed by the previous owner. Sort of a bizarre error on Vintage's part to ship a pair of mismatched wheels. Wonder if Vintage will be willing correct the matter for me? They seem to have a good reutation on the various forums. Guess I'll find out.
The Vintage Wheel website says they are available in 3.75" back space unless for use with adapters, then they are available in 4.25", 4.65", or 5". I suspect they'll machine whatever you want.
So my question is:
  • Is 3.75" the common back spacing for 8.5" wide front wheels on SPF cars? The 4.25" back space wheel actual looks to be a better fit in the wheel well.
  • Is the back spacing measured from the outer edge of the wheel to the mounting surface? I just placed a straight edge across the rim and neasured to the hub surface.
  • I take it the SPF pin drive spindle is not considered a pin drive adapter? I'd usually call an adapter as that you would bolt on to a lugged hub/spindle assembly to adapt to pin drive. Is this correct?
Best,
Kelly
SPF GT40 Mk II, 74 Pantera GTS, 64 Corvette Roadster
kcoffield is offline
Similar Threads
All wheel 016 Joz GT40 Tech - Powertrain/Transaxles 6 25th May 2008 06:52 PM
revolution wheel chris want GT40s Wanted, and Parts or Services Needed 0 7th February 2008 02:52 PM
GTD 40 steering wheel simon jude GT40 Tech - Exterior, Interior, AC, & Trim 2 22nd October 2006 11:40 AM
wheel offset Kevin Carey GT40 Tech - Chassis,Brakes,Tires,&Wheels 4 13th October 2005 07:16 PM
Wheel Centers llarsen GT40 Tech - Exterior, Interior, AC, & Trim 9 17th August 2005 05:13 AM
