I've got a Quicktime bellhousing and an RBT.
The motor's in :thumbsup:, and the bellhousing is essentially resting on the lower crossmember. Everything is loose, and I suppose the rear of the engine has enough "wiggle room" to be raised up a bit...
The question is this...the RBT mounting flange goes in a complete circle, with bosses for a number of through-bolts (to bolt to the bellhousing), including one at the bottom. There is no provision for this through-bolt on the bottom of the Quicktime bellhousing (that is where the bevel is).
Do I just lift up the motor and bolt everything together, leaving the RBT unmodified, or shave off the lower portion of the RBT (including the boss for the un-needed throughbolt)?
I suppose I can see how the mounting "ears" of the RBT line up with the bosses of the upper crossmember, and that will answer my question....but can't do that until tonight, and I'll be thinking about it all day.
Anyone want to chime in and save me from being distracted all day long?
