P2270 Official Weight Certificate
Glenn B.
Just registered P2270 in the State of Texas. They required a certified weight certificate to be presented with all the other documentation. She weighed in at 2,560 lbs. Certificate attached.
MKIIA body with luggage bins
427 FE all aluminum big block - Single Holley 4 BBL
Wet Sump
Dual Oil Coolers
RBT ZF Transaxle
Avon tires
1/2 tank fuel
All fluids
No Spare
No driver
Glenn B.
Randall,
If I remember correctly, you have a 351W stroker with an iron block and a single 4BBL and a single oil cooler. Netting out my second oil cooler with the associated plumbing and the luggage boxes probably results in a net difference of ~100lbs. between an aluminum block FE big bore and and iron block Windsor. Less than I thought it would be. Registration is complete.
It's officially legal.
Yes, Glennn I know..........just for comparison only. Two GT40's in Spicewood, Texas who would of thought. Hope you can enjoy the car some more considering you are still working in California.
Randy
