Go Back   GT40s.com > >
Superformance GT40s Sponsored by Superformance.
Thread Tools Display Modes
Old 11th November 2014, 01:02 AM   #21
Dave Hood's Avatar
Dave Hood
GT40: SPF 2135
Re: Spf 2317
Ron:
Dennis' engine builder did a rebuild on my engine about three years ago. It's run great ever since, and I'd highly recommend him.
Dave
Dave Hood is offline   Reply With Quote
Old 11th November 2014, 12:13 PM   #22
Ron Scarboro's Avatar
Ron Scarboro
Gold Supporter
GT40: Not right now
Re: Spf 2317
Originally Posted by MHNCO View Post
Which wheel and tire package are you planning on?
Borrani wheels
Not too sure on tires yet. Likely Avons, 215 & 275
Ron Scarboro is offline   Reply With Quote
Old 11th November 2014, 04:42 PM   #23
Doc Horror's Avatar
Doc Horror
6 Tenths
Netherlands
GT40: GTD
Re: Spf 2317
Avons are the best.... (My 2cents)
Doc Horror is offline   Reply With Quote
Old 11th November 2014, 05:32 PM   #24
MHNCO's Avatar
MHNCO
GT40: SPF 2161
Re: Spf 2317
Anyone running the 275s on a Std width MkI?
MHNCO is offline   Reply With Quote
Old 11th November 2014, 08:03 PM   #25
Mike Drew's Avatar
Mike Drew
GT40: None, yet!
Re: Spf 2317
Ron--I love the stacked taillight rear end. Is that the optional narrow rear end? If so will you run narrow rear wheels as well?
I have a sneaking suspicion that the SPF Wilwood brakes might not clear Borranis. I hope I'm wrong!!!
Linden green looks fantastic too. RHD, sill shift, narrow tail--you're building my dream car!
Mike Drew, Vacaville, CA (
'72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1....
Mike Drew is offline   Reply With Quote
Old 11th November 2014, 09:42 PM   #26
Mark IV
I Have No Life
GT40: Superformance
Re: Spf 2317
1) Yes, narrow tail, stacked lamps.
2) Wilwoods will clear the Borranis. Factory is doing hubs with splines to fit as we speak.
3) As Ron posted, NOT Linden Green but a 50's/60's Porsche color
The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get...
Mark IV is offline   Reply With Quote
Old 12th November 2014, 10:51 AM   #27
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Re: Spf 2317
Standard on the borranis for street is: a) Front 215 60 R 15 Yokohamas b) Rear 235 60 R 15
DRB#5
351W/408 TWM FI. AFR 205s 930 Porsche LSD
wbmusarra is offline   Reply With Quote
Old 12th November 2014, 10:59 AM   #28
Mark IV
I Have No Life
GT40: Superformance
Re: Spf 2317
Here is the recommendations from the Borrani site:
GT40 65-69
8.00x15 RW 3924 42 RCS 72 record 245/60VR15 Avon CR6ZZ
9.00x15 RW 3925 42 RCS 72 record 275/55VR1 5 Avon CR6ZZ
6.50x15 RW 3926 42 RCS 72 record 215/60VR15 Avon CR6ZZ
7.50x15 RW 392811 42 RCS 72 record 225/65VR1 5 Avon CR6ZZ
72 is the spoke count and "record" is the wheel model
You can run the 9" in the rear of the "narrow" tail as it is second generation design and the wheel with a 275 will fit.
Old 12th November 2014, 11:54 AM   #29
IanAnderson's Avatar
IanAnderson
GT40: Dax 40 Mk1 (Rov
Re: Spf 2317
Rick
With the wire wheels, have they got them sealed or do you still have to run with inner tubes?
If with tubes will the Avons work correctly with them as they are a tubeless high performance tyre?
DAX GT40. Morgan 3.9 EFi, Worked by John Eales.
IanAnderson is offline   Reply With Quote
Old 12th November 2014, 03:38 PM   #30
Mark IV
I Have No Life
GT40: Superformance
Re: Spf 2317
I understand the Borranis can be done as tubeless with sealant on the spoke ends. We had the Kelsey-Hayes wires used on T-Birds done that way as well and it worked OK most times.
Old 17th November 2014, 07:05 AM   #31
P2164's Avatar
P2164
Gold Supporter
GT40: SPF 2164 07-07
Re: Spf 2317
I have always like the look of wires and on a MK1 it will be stunning, sounds like you got a perfect package.
SPF GT40 MK1
and a bunch of other stuff
Typing is not my bag
P2164 is offline   Reply With Quote
Old 14th August 2017, 08:43 PM   #32
Ron Scarboro
Gold Supporter
GT40: Not right now
Re: Spf 2317
So, long time, no update. If stories make these cars great, then mine will be super great. After 3 years of nothing, I've gotten the car back and will be completing it myself.
Questions for those who have done it.
- How many hours did it take you?
- I have motor, will be using the Safir clutch and RBT Transmission, what else do I need?
- Is there a resource for builds? I understand there is no manual.
Thanks,
Ron Scarboro
Old 14th August 2017, 09:12 PM   #33
Mike Drew's Avatar
Mike Drew
GT40: None, yet!
Re: Spf 2317
Ron, welcome back!
Did you buy a complete Safir clutch setup including bellhousing and flywheel? The original (and Safir) GT40 setup is much smaller than a standard Ford unit. The starter is placed closer to the centerline of the gearbox and may interfere with a generic oilpan, so it's critical that you mock up the whole drivetrain before trying to install it.
How do you plan to actuate the clutch? I don't know if the generic SPF clutch slave setup is compatible (because I know nothing about it). The Original setup mounted a slave cylinder vertically on the bellhousing, which actuated a curved arm on the gearbox. That arm is hard to come by although I assume Jay Cushman can probably supply one.
Lots of little details ahead of you!!! Keep us posted!
Old 15th August 2017, 08:50 AM   #34
Ron Scarboro
Gold Supporter
GT40: Not right now
Re: Spf 2317
Mike,
Thanks, I will be doing the Safir complete clutch and the Aviad pan was purchased to accommodate that setup. I'm unfortunately at ground zero on a transaxle, but have gotten on the list from RBT so I have time to start figuring it all out.
Car is in Raleigh now, but it'll be the weekend before I can get it to my shop.
Best,
Ron
Old 15th August 2017, 10:32 AM   #35
Mike Drew's Avatar
Mike Drew
GT40: None, yet!
Re: Spf 2317
I confess to having just enough knowledge to be dangerous
The original Dash 0 and later Dash 1 gearbox case was a bit smaller than the more common Dash 2. The bellhousings don't interchange both because of the dimensional differences and a completely different bolt pattern.
Is the Safir bellhousing a scaled up version of the original intended to accommodate the Dash 2? If you had a perfectly original bellhousing it would require either an original GT40 gearbox or a Dash 1 from a Mangusta.
I suspect the Safir setup is intended to support a Dash 2 but the question bears asking!
Old 20th December 2017, 08:48 PM   #36
Dave Hood's Avatar
Dave Hood
GT40: SPF 2135
Re: Spf 2317
Hi Ron:
Just checking on the status of your car. Has it arrived at Olthoff's, and have you decided on an engine builder? My engine was rebuilt a few year's back by Dennis' preferred shop (former NASCAR builder) in Denver, NC. They did a very nice job.
Dave
Old 8th January 2018, 11:10 PM   #37
Randy
Re: Spf 2317
I have a New RBT zf.No waiting!
Randy is offline   Reply With Quote
Old 12th January 2018, 10:00 AM   #38
Ron Scarboro
Gold Supporter
GT40: Not right now
Re: Spf 2317
Dave,
Sorry, for the delayed response. My Mother passed in November and that has consumed much of my attention for the past couple of months. The car was delivered to Olthoff in 2014 but never completed waiting on a gearbox. When the gearbox arrived we had something of a misunderstanding and I took possession of the car unfinished.
The motor was built using Gurney heads by a former Nascar engine builder local to Raleigh.
Randy,
I sent you an email regarding the gearbox.
Thanks all,
Hopefully as the weather warms I can get back on the task.
Best,
Ron Scarboro
Old 12th January 2018, 09:16 PM   #39
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Re: Spf 2317
So sorry for your loss Ron....
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Old 5th March 2018, 05:15 PM   #40
Ron Scarboro
Gold Supporter
GT40: Not right now
Re: Spf 2317
So, FINALLY things are moving. Got the car over to the shop today. Clutch and airbox ordered from Safir, and a big thanks to Rod Brace for the ZF Gearbox that will be coming.
Couple of pics.
Spf 2317-image2-3-jpeg   Spf 2317-image3-1-jpeg   Spf 2317-image1-3-jpeg
Forum Jump
