Just took 50th anniversary Lemans win drive. Even after having this beast for a while, can't get over the feeling this 427FE monster produces, and the straight pipes turn it into an 'e-ticket ride'!
To business...OEM oil temp sensor wire that runs through the wrapped wire strand appears to worked it's way loose from actual sensor (that is on top of oil filter). Is the best way to fix to solder the wire back into the sensor?
Thanx
Mark
Thanx
Mark
