One of my seat rivets came apart on the driver's side. :sad: One half of the rivet is trapped under the seat cover and the other is loose. If I remember correctly from the "How It's Made" television series, the part of the seat that is riveted is simply a wide strip of material, glued to the foam down the center.
Should I remove the riveted strip and tap the halves back together, then re-glue?
