Go Back   GT40s.com > >
Superformance GT40s Sponsored by Superformance.
Thread Tools Display Modes
Old 21st June 2017, 08:11 PM   #1
RWoerz's Avatar
RWoerz
6 Tenths
GT40: GT40 MKI P2197
LHD Shift Linkage
I posted this in the "Original GT40s" area but I might have better luck here with other SPF owners. Does anyone out there have pictures of their RHD shift linkage out of the car. How did SPF solve these problem? What does the spherical bearing look like installed in an SPF car? All questions an inquiring mind want to know. As the hole for the spherical bearing is on the wrong (left drivers side) of my car I need to drill a hole on the right passenger side and I want to make sure it's in the right place. If only I had ordered a car with the steering wheel on the right side. What was I thinking.
Original Post:
I could use some help. I'm building a shifter and it would be very helpful if I knew how long the cabin shift rod extends into the sponson past the spherical bearing mounted on the firewall. Length from the firewall to the centerline of the forward U-joint of part 31. Maybe someone out there has part 31 from the drawing laying around (lol) they could post a picture of with a tape measure next to it (it could happen). Also the length of the long portion of part 31.
It would also be helpful to know the downward angle of the rod in .
RHD Shift Linkage-scan-jpg
Richard
GT40 MK1 P2197
1966 GT350H 6S1844
1997 Eagle Talon Tsi
RWoerz is offline   Reply With Quote
Old 2nd August 2017, 02:49 PM   #2
ROBY427
France
GT40: SPF GT40/P2193
Re: RHD Shift Linkage
Original Post:
Hi Richard,
Did you get a reply about your question ?
If no I can check in my car if you want (4/5 screws to remove the linkage cover).
OliveR
ROBY427 is offline   Reply With Quote
Old 4th August 2017, 10:49 PM   #3
RWoerz's Avatar
RWoerz
6 Tenths
I think I'm good for now thanks for the offer. This thing has turned out to be harder than I thought. Mostly just no room to work.
RHD Shift Linkage-0707171449_hdr-jpg   RHD Shift Linkage-0718171530_hdr-001-jpg
Richard
GT40 MK1 P2197
1966 GT350H 6S1844
Tags
bearing, part, shift, spf, spherical
Forum Jump
