Go Back   GT40s.com > >
Superformance GT40s Sponsored by Superformance.
Thread Tools Display Modes
Old 28th March 2018, 03:32 PM   #1
Chris Kennedy
GT40: None yet
Ground Clearance
Hi:
Pending the arrival of my MKII, I have been giving all sorts of thought to practical issues, such as ground clearance, particularly at the front. My car will be mainly for road use, and, obviously, I will be extremely careful, but a general question I have is what have people's experiences been as to ground clearance issues, and would welcome any suggestions (I live in Houston, which has the worst roads on the planet). I find myself looking at every road I travel now with new concern, and stay awake at night at times plotting how to get from point "A" to point "B", what are acceptable roads etc.
Thanks!
/s/ Chris
Chris Kennedy is offline   Reply With Quote
Old 28th March 2018, 05:25 PM   #2
Walt Williams
2 Tenths
GT40: CAV GT40
Re: Ground Clearance
I have about 3 1/2 inches of ground clearance.. Can noT go any higher. Going up the wrong driveway can result in a bad day.. No speed bumps, gas station tank covers.. Be careful.
I installed 2 nylon scrub blOcks on my chassis... They rub first.
Walt Williams is offline   Reply With Quote
Old 28th March 2018, 05:52 PM   #3
jac mac's Avatar
jac mac
I Have No Life
New Zealand
Original prototype & Mk1 is 4.8", MK3 is 5.25", & MK2 is 3.9". So I guess you use what you choose, 'wisely' from day one.
AMGT Rep Steel Mono x Plans, FE328 T44R.
[email protected]
Old 28th March 2018, 06:15 PM   #4
Chris Kennedy
GT40: None yet
Yeah, Owner's Manual says 4.125" to 4.75".
Thanks, everyone, for you replies!
/s/ Chris
Old 28th March 2018, 09:08 PM   #5
kgschrader's Avatar
kgschrader
They're all silver
GT40: SPF MkII 2155
Originally Posted by Chris Kennedy View Post
Hi:
Thanks!
/s/ Chris
Chris,
Houston? I'm near.
I have had my car for... wow.... 11 years now.
I tried being nice and planning and going at an angle, but there is always somewhere that will bite you.
The underneath of my front clip has 'rash', to say the least.
You'll be driving down the streets of Houston, as you say, and suddenly there's a dip and yep... you hear a bang/crunch/whatever.
The car is low, but the biggest problem is the front hangs out so far.
Hope that helps. The solution is raise the car up, but I refuse to do that.
FWIW,
Kirby
71 Pantera 1661, 71 Pantera 1921
GT40 Mk II 2155
16 GT350
17 Raptor
kgschrader is offline   Reply With Quote
Old 28th March 2018, 11:40 PM   #6
Silver66fb's Avatar
Silver66fb
GT40: SPF #P2334
Chris,
I set my Mark II to 4.5" front clearance, 5" rear clearance (roughly). I've already scrubbed it in a few locations. I will have it filled and repainted, at some point. The choice is really whether you drive it and enjoy it (carefully) - or look at it. The choice was easy for me. If you can afford the car, you can afford a trip or two to the body shop for the front clip.
My two cents.
Tim Terry
SPF GT40P/2334
Silver66fb is offline   Reply With Quote
Old 29th March 2018, 08:07 AM   #7
Chris Kennedy
GT40: None yet
Originally Posted by Silver66fb View Post
Chris,
My two cents.
Thanks for the replies-----I fully expect scrapes and rash, my main concern was the likelihood of really serious disasters. My overall plan is to stick to the best of the main roads to get out of town and to keep to an absolute minimum any driving around town. Frankly, after I get the car inspected and registered I don't anticipate taking the car anywhere in town except to get out of town! I tell everyone that what I really want to do is to simply get lost with it "out west".
/s/ Chris
Old 29th March 2018, 06:22 PM   #8
Dave Hood's Avatar
Dave Hood
GT40: SPF 2135
Chris:
Several years back, I had Dennis Olthoff install a front lift system called RamLiftPro.
ramliftpro
The system works well, and provides a few extra inches of clearance when I need it. But it's not cheap, and to install it you'd need to shorten your front springs. Not a problem for street use, but may not be good if you plan to do any track driving.
At a minimum, follow Walt Williams' advice and install scrub blocks to absorb any initial contact. When you drive over any speed bump or curb, always hit it at an angle.
I'm also a HUGE believer in 3M Paint Protection Film. While that won't help you with the ground clearance issue, applying the film in all the right places will keep your car looking new for years. And you really can't even tell it's been installed. Send me a PM if you want more detailed recommendations on where to apply the film. I've got 14,000 miles on my car, and it's been a life saver.
Dave Hood is offline   Reply With Quote
Old 29th March 2018, 11:27 PM   #9
40bud's Avatar
40bud
GT40: GTD Finished in
An aluminum Sheet metal piece pop riveted to the underside of the front nostril ( you can't see it when looking at the car) will take care of the road rash that peels away the fiberglass. Just replace it whenever necessary.
40bud is offline   Reply With Quote
Old 30th March 2018, 09:01 AM   #10
Silver66fb's Avatar
Silver66fb
GT40: SPF #P2334
40 Bud - do you have a photo of that?
Tim Terry
SPF GT40P/2334
Old 30th March 2018, 10:57 AM   #11
Chris Kennedy
GT40: None yet
Thanks---I have heard of this from other sources and it would be great to see a picture.
/s/ Chris
Old 30th March 2018, 12:47 PM   #12
weisserheilbronn's Avatar
weisserheilbronn
Germany
GT40: SPRF40
http://www.gt40s.com/forum/247453-post25.html
weisserheilbronn is offline   Reply With Quote
Old 7th April 2018, 03:59 PM   #13
40bud's Avatar
40bud
No picture but here is a drawing I used for the GTD.
Ground Clearance-img20180407_12463776-2-jpg
Tags
clearance, ground, issues, point, road
Forum Jump
