Go Back   GT40s.com > GT40 Replica Manufacturers' Corner > Tornado GT40 Discussion
Tornado GT40 Discussion Sponsored by Tornado Sports Cars.
Old 04-08-08, 11:12 AM   #161 (permalink)
Scott Calabro's Avatar
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Rep Power: 9 Scott Calabro is a glorious beacon of light
Re: Tornado TS40 #875
Hi Gregster,
Yes wheel alignment was performed by me in accordance with the TS40 Build Manual.
It is very simple and straight forward to do.
The car is set up now for street driving.
Hopefully that will be soon.
Cheers,
S
TORNADO SPORTS CARS USA
WWW.TORNADOSPORTSCARS.COM
413-977-4408
Scott Calabro is offline
Old 04-08-08, 11:20 AM   #162 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Rep Power: 32 Bill D has much to be proud ofBill D has much to be proud of
Man, things are really moving fast Scott. Do you think you'll be on the road by summer?
Bill D
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 04-08-08, 11:22 PM   #163 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Bill,
Yes.
S
413-977-4408
Old 04-12-08, 05:15 PM   #164 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Its been a few days since my last update.
Here is what has been accomplished;
Installed the flywheel and clutch assy.
Installed the bellhousing and transaxle.
Installed the clutch slave cly. and bled system.
Installed the starter motor.
Installed the rod type shifter linkage, I must say its quite positive and slick with a very short throw.
Installed the half shafts.
Installed the exhaust system.
Pressure tested the cooling system, to ensure no leaks before engine coolant fill and subsequent start.
Almost ready for body work
Cheers,
S
ID:	28895  Click image for larger version
ID:	28896  Click image for larger version
ID:	28897  Click image for larger version
ID:	28898  Click image for larger version
413-977-4408
Old 04-16-08, 07:33 PM   #165 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
OK the last couple of days....
Cut out all the holes in the GRP body parts
Started Installing the rear clip
Tommorrow the spider front apron
Cheers,
S
ID:	28952  Click image for larger version
ID:	28953  Click image for larger version
ID:	28954  Click image for larger version
ID:	28955  Click image for larger version
413-977-4408
Old 04-16-08, 07:55 PM   #166 (permalink)
Bill D's Avatar
Bill D
I Have No Life
WOW! What great progress Scott! The car is really coming together and looking great!!
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 04-17-08, 09:38 PM   #167 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Thanks Bill
Tonight an important step in a Tornado build, aligning the roof spider.
Doors have been rough trimmed, the winshield dropped in for fit then the front apron can be trimmed, then riveted and bolted down.
Also installed the spider to rear clip, gap adjustment stops. These have been just rough installed as they get finished adjusted/trimmed during paint.
Tomorrow installation of the wiper motor/drive setup and installation of the front clip and hinge system.
69 Days.
Cheers,
S
ID:	28966  Click image for larger version
ID:	28967  Click image for larger version
ID:	28968  Click image for larger version
ID:	28969  Click image for larger version
413-977-4408
Old 04-18-08, 12:27 PM   #168 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Had a great morning today!
875 outside with the front and rear clips hinged open!
Later today the scissor stops for each clip and the wiper motor assy.
Enjoy!!!!!!!!!!!
S
ID:	28971  Click image for larger version
ID:	28972  Click image for larger version
ID:	28973  Click image for larger version
ID:	28975  Click image for larger version
413-977-4408
Old 04-18-08, 05:21 PM   #169 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
This afternoons work;
Installed the wiper motor and drive cable.
Note the OEM type pre terminated harness end on the motor assy.
Still need to flare the end of the drive tube and cut the cable to length.
Installed front and rear clip scissor stays.
This weekend all the windows/lenses will be fit ... maybe .
S
ID:	28978  Click image for larger version
ID:	28979  Click image for larger version
ID:	28980  Click image for larger version
413-977-4408
Old 04-22-08, 08:44 PM   #170 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Tonight the the TSC "Twin Pumps and Filters" option was mocked up with fuel lines.
The cockpit closure panels go on at paint, then the filter/regulators get mounted.
S
ID:	29033  Click image for larger version
ID:	29034  Click image for larger version
413-977-4408
Old 04-25-08, 08:10 PM   #171 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Todays activities;
Started ignition wire routing setup so I can cut the wires to length and crimp the ends then put the boots on.
Layed out the rivet pattern for the left cockpit closure panel and fit the oil cooler then fabbed the hoses.
Fit the coolant purge tank and hose setup.
Body and paint soon
S
ID:	29116  Click image for larger version
ID:	29117  Click image for larger version
413-977-4408
Old 04-26-08, 12:57 PM   #172 (permalink)
Andy Sheldon's Avatar
Andy Sheldon
Sponsoring Vendor
GT40: Tornado TS40
Rep Power: 10 Andy Sheldon is a splendid one to behold
Scott
Nice job. Looks good.
And in just how many hours or days?
Andy
Andy Sheldon
TORNADO SPORTS CARS
www.tornadosportscars.com
Andy Sheldon is offline
Old 04-26-08, 06:28 PM   #173 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Thanks Andy,
Currently 79 days from crate to this point.
It is going fast & smooth, thanks for the great package.
More pictures will be up soon.
Cheers,
S
413-977-4408
Old 04-28-08, 09:28 PM   #174 (permalink)
Gregsterv
GT40: none yet!
Rep Power: 1 Gregsterv is on a distinguished road
Good Day Mr. Calabro,
Your pace is a little intimidating!!! Really appreciate the attention to detail you are allowing us to see. However....What do I see in the background of one of your last engine shots? Is that an MB, must be your every day car.
Thanks again and please keep us posted!
Gregsterv is offline
Old 04-28-08, 09:40 PM   #175 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Thanks for the kind words Gregster!
Cheers,
S
413-977-4408
Old 05-03-08, 03:32 PM   #176 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Just a quick update today.
Rigged the throttle cable for the Webers.
It is visible on the front of the engine with the spiral anti - chafe wrap on it.
S
ID:	29342  Click image for larger version
ID:	29343  Click image for larger version
413-977-4408
Old 05-03-08, 05:19 PM   #177 (permalink)
Bill D's Avatar
Bill D
I Have No Life
Scott
Your car is looking great!! Your progress in unprecedented!!
