Go Back   GT40s.com > GT40 Market Place > Vendor and Manufacturer Announcements
Vendor and Manufacturer Announcements Information and releases from GT40.com sponsors.
LinkBack (8) Thread Tools Display Modes
Old 07-02-09, 04:07 PM   #341 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Re: ZFQ new proposed GT40 transaxle
Hi Rick
Custom headers, Engine bay mod's by Hi-Tech, modification to starter position on ZFQ bellhousing and I think the rest was quite straight forward. I think the installation is really good and solves the emission problems in Australia.
regards
Chris
Picture below shows modified starter position.
Chris Melia is offline
Old 07-02-09, 04:23 PM   #342 (permalink)
Just to show that the body fits.
Chris
ID:	39763   Click image for larger version
Old 07-03-09, 04:20 AM   #343 (permalink)
jferraro's Avatar
jferraro
GT40: RCR40
Tell John he has a nice number plate! Similar to mine!
Build site:
Gulf birthday cupcakes anyone?
jferraro is offline
Old 07-12-09, 05:44 PM   #344 (permalink)
evomind's Avatar
evomind
GT40: SPF 2223
chris,
do you recommend changing the trans fluid after the first 500 miles or so with the zfq?
my car now lives!
thanks
427 aluminum block fuel injected engine ZFQ trans.
evomind is offline
Old 07-12-09, 11:15 PM   #345 (permalink)
3 Tenths
Hi Mike
You should change the oil after 1000miles and we recommend using Silkoline Syntran 5 synthetic oil. Silkoline.com
Martin Gough
MartinGough is offline
Old 08-02-09, 12:38 PM   #346 (permalink)
Hi guys
just a note to say that the ZFQ team were extremely happy to see Dennis Olthoff in his Superformance GT40, fitted with a ZFQ transaxle thrash many original GT40s on track at Road America, including the Holman Moody 7 Litre Mk11.
The ZFQ is setting the modern standard for high powered GT40s. Olthoff attained over 190mph plus on track and was leaving two distinct rubber trails from mid bend on every corner, putting the 540 rwhp down through the Quaife ATB differential.
Well done Dennis
regards
Chris Melia.
Old 08-02-09, 01:03 PM   #347 (permalink)
Thats the way to do it?
Name:	Olthoff thrashing holman1.jpg
Old 08-29-09, 05:56 AM   #348 (permalink)
GB
creempuf
Chris,
A question about the zfq for a porsche application. As you know on a porsche motor, the porsche transmissions have the output shafts below the input shaft. As I see from the drawings on the quaife website, the zfq is the opposite. therefore on a porsche application, wouldnt the zfq box be inverted as in a pantera?
creempuf is offline
Old 08-29-09, 11:33 AM   #349 (permalink)
Hi
The G50 in the 911 has probably 3.5" more ground clearance than your 917 so to enable the drive shafts to sit level with the engine as low as it can go you need the output shafts higher than the input shaft, that's why they flip the G50 for Ultimas and GT40s.
Dont worry it will work out. I would run the 917 with 5" rear ground clearance for road use and 4" to 4.5" for track use.
Porsche factory drawings put the transaxle output centres at 200mm above the bottom of the chassis and 290mm from the road with 90mm of ground clearance
Chris.
Old 08-30-09, 06:21 PM   #350 (permalink)
GB
creempuf
I certainly dont have a real 917 motor. I'm using a 993 motor. on a real 917, the transmission input shaft runs off the engine output shaft the sits a couple of inches below the crankshaft as opposed to a typical 911 motor where the input shaft runs direct off the crank, therefore the input shaft location is higher on a 911 motor. My point is, I was originally going to use my 930 box(flipped ring gear) with its typical porsche orientation with the input shaft above the output shafts, So I figured when I switched to the ZFQ, the right thing to do would be to invert the box so it is in the exact same orientation as the 930 trans. Seems logical. With the standard zfq orientation I have a couple of concerns. 1. the output shafts will be too high, half shafts will angle down like a ski slope, looks nasty. 2. the higher trans will interfere with the 917s frame triangulation at the rear. I want to keep the frame to exact 917 spec. here is a photo with the 930 trans mounted to the frame. notice the frame tubes above the red oil fill plug, that will be a clearance issue with standard zfq orientation.
Name:	jim dunham garage dec 07 (1).jpg
creempuf is offline
Old 08-30-09, 06:34 PM   #351 (permalink)
jac mac's Avatar
jac mac
I Have No Life
New Zealand
ZFQ uses a hypoid R&P which makes it like the G50 rather than 930, so if you fit it to your application as pictured you will have 5 reverses & 1 fwd . I dont think ,( but Im sure Chris will correct me if Iam wrong ) that they make a reverse image version of the R&P for the ZFQ to allow its use in the std Pantera position or the likes of yours..yet. Not quite as simple as the shaft load paths change direction as well.
Jac Mac
jac mac is offline
Old 08-30-09, 07:21 PM   #352 (permalink)
Hi
As I said above the output shafts on a 917 Porsche are 200mm from the bottom of the chassis and you can fit the output shafts on the ZFQ at that height. The transaxle you have ordered is a special build with a 5" extension on the input shaft to place you 6 banger 911 engine closer to your C of G. Russ Hughes has researched the dimensions already for his excellent 917 build and is happy with the transaxle dimensions and output shaft positions.
The 917 runs a much lower ground clearance than the 911 Porsche so running a 911 transaxle in its usual orientation will i.e. output shaft below input shaft will give you drive shafts that run up towards the hubs not a good idea. You want to keep your motor as low in the frame as you can to help with the C of G.
So relax the ZFQ will fit
Chris.
Old 11-12-09, 05:26 PM   #353 (permalink)
Hi Ron
Has the last page disappeared? After Martins post?
Chris.
Old 11-12-09, 05:27 PM   #354 (permalink)
Ron Earp's Avatar
Administrator
GT40: None.
I moved it to it's on thread in the interest of keeping this thread on the intended vendor topic. I can easily put it back if that is what you'd like. Sort of one of those "damned if I don't damned if I do things" that comes up as an admin.
Ron Earp is offline
Old 02-22-10, 12:23 AM   #355 (permalink)
gtrclive's Avatar
gtrclive
Canada
GT40: KVA
Hi Chris YHM......
Ps whens he next batch of Boxes set for production ??
gtrclive is offline
Old 02-23-10, 12:53 PM   #356 (permalink)
csdilligaf
So they have all been sold to this point? And do you have a website?
thanks,
csdilligaf is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/vendor-manufacturer-announcements/20751-zfq-new-proposed-gt40-transaxle.html
Posted By For Type Date
daytona or GT40 This thread Refback 02-27-07 08:24 PM
daytona or GT40 This thread Refback 02-27-07 08:04 PM
Mid-Engine Transaxle Tech - Page 2 - Corner-Carvers Forums This thread Refback 02-14-07 02:58 PM
Mid-Engine Transaxle Tech - Page 2 - Corner-Carvers Forums This thread Refback 02-14-07 02:20 PM
Mid-Engine Transaxle Tech - Page 2 - Corner-Carvers Forums This thread Refback 02-14-07 01:50 PM
LocostBuilders This thread Refback 02-09-07 06:28 AM
LocostBuilders This thread Refback 02-09-07 06:25 AM
GT40s.com This thread Refback 02-08-07 07:36 AM
