| Re: Interest in group purchase The average price of a complete (TWM throttle bodies, fuel rails, manifold, manifold mounted linkage, vacuum plenum, TPS, ECU/harness/O2 sensor, MAP, air and water temp sensor, injectors, Aeromotive pump and filter, throttle cable and machined air horns with 304 stainless mesh) The average 427 FE setup is $7,500.00, a small block is $6,800.00. The group purchase price will be 10% less or $750.00 less for a FE and $680.00 less for a small block. As good as the IRS incentive check and I'm not borrowing from China! |
