- Motor is 427 sideoiler (not dyno'd)
- CR is 10:1
- Heads and Weber intake ported
- Cam data is:
Duration at .020 is 270 intake/274 exhaust
Duration at .050 is 244 intake (14/50)/248 exhaust (56/12)
Intake maximum Lift is 108 degrees
Exhaust maximum Lift is 112 degrees
Lobe Separation is 110 Crankshaft Degrees
Both valves are open for 26 degrees
Lobe lift is 330 degrees
Gross Lift for 1.76 Rockers is .580
Valve Lash is .18 hot on both sides (.14 cold)
- Engine analyzer Pr v3.3 showed the following
Engine RPM 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500
Brk Tq, ft lb 348 428 515 528 582 601 569 547 485 407
Brake HP 132 204 294 352 443 515 542 573 554 503
I am thinking 44 chokes, 180 mains, 210 air corr (230 or so seems what to big given hp is all genertaed below 6000rpm) .75 idle, 110 idle holder
Thoughts?
Thanx
Mark
- CR is 10:1
- Cam data is:
Thoughts?
Thanx
Mark
