Dwight
I have done a "little" searching on what oil would be best for my '88 G50 trannie. Fully-synthetic Red Line and Mobile 1 were recommended.
Which one? They have a lot of different oils and I don't want to put the wrong one in my trannie.
Street car, no racing.
Dwight
From one of the ads for Red Line products;
Red Line 75W90 Gear Oil
-Most popular Red Line gear oil, with thousands of applications for passenger cars, light trucks, and racing vehicles
-Contains additional friction modifiers for suitability with clutch-type limited slip differentials - for most LSDs, no additional friction modifiers are required
-This product is not designed for use in most manual transmissions or tranaxles, since the extreme slipperiness may cause synchronizer mesh issues that lead to shifting problems
-Recommended for API GL-5, GL-6, MT-1, MIL-L-2105E, and SAE J2360
About Redline Gear Oil for Differentials:
-Fully-synthetic formulas created from polyol ester base stocks, offer excellent lubrication under extreme conditions
-High viscosity-index (VI) to provide relatively constant viscosity and film thickness with varying temperature change
-Ester base stocks and friction modifiers provide additional slipperiness to lower operating temperatures by reducing the sliding friction in hypoid gears
-Superior shear stability and reduced oxidation compared to other synthetics and conventional gear oils
-Exceed API GL-5 specifications
-Engineered to provide the highest degree of protection and improvement of differential efficiency for better mileage, longer drain intervals, and less wear
Dwight
